1 - 10 of 10 Posts
I know I seen someone else post this but now I cant find it, but I was wondering how much is involved in changing a VN800B into a VN800A?? Is it just the fenders, taillight, and forks or am i missing more?? Just curious. Thanks.
Ahhh Crap
Handlebars, seat, front wheel, tire and by the time you get done with the conversion process you'll wish you'd just bought an 800A.
Barrett Motorcycle Repair
lower triple tree is drilled and tapped for the b fork tins , rear fender , tail light , i think even the headlight is different
Yet another 800 Bobber...
Yes the A model has two degrees more rake than the B model, according to the specifications. Comparing them side by side you see that the A model leans more backward, probably because of the bigger front wheel. I don't know if the extra rake comes from this fact, or if the frames are actually different.
Most of it has already been mentioned, but if you want an 100% authentic VN800B:
  • Front wheel + wheel axle
  • Fenders (front + rear)
  • Lights (front + tail)
  • Seat
  • Handlebars
  • Fork (well some of the parts here are the same)
  • Kickstand
  • Frame?
  • I think they have different sprockets?
  • Paint
  • I think that's it?
But hey you don't have to change *everything* :)
I've read somewhere that the engine on the A model is set to be quicker than the B model, but that might just be because of the different sprocket ratios? Seem to be identical in the spec though as far as I can see?
Dave, I am pretty sure they are different. I think the A and B uses different disc rotors as well
Discussion Starter · #10 ·
thanks for all the info. yea buyin an A would be much simpler but they are alot harder to find, so i was just basically weighin my options. plus all the non kawasaki people i could tell em i started with this and ended with this and look like a professional bike builder lol.
1 - 10 of 10 Posts
