1 - 10 of 10 Posts
I AM THE DAD FROM ****
Had a knocking noise coming from the left hand side so I took the left hand casing off to find my balancer dampers were worn and damaged (23,000 mile on the clock) took off the metal balancer and now, when I go to replace it with new dampers fitted ,realise that the dot on the balancer shaft which I have to align the balancer too is not there .
How on earth do I find out which is the correct way to line them up?
I can't imagine why the mark should not be present otherwise it would have been picked up at factory !
D in the picture....
Discussion Starter #3
There are some marks on the balancer shaft itself where the balancer has been loose which I am guessing have scrubbed it away.
Ummm screwed comes to mind and i don't mean the Bike !!
You need to find someone with another VN800 that's got the case off and can give you detailed info on where the Shaft/Balancer sits in relation to either number 1 or 2 cylinder TDC, And the chances of that are remote :(
Good luck :)
Machinist For Sale/Rent
the marks are there, I'd almost bet a free assembly job on it. They are not all dots, nor are they all straight lines. I've seen a shaft with a dot and a balancer with a hash mark, and any other combination you may think of but I always found a mark once I scoured it with a scotchbrite pad lightly.
Discussion Starter #6
Is there any way we can set the balancer up by lining up the marks from the opposite end of the balancer shaft? (clutch casing side).There are marks which line up will this give us the position of the balancer plate?
Discussion Starter #7
Good luck :)
Hi chap just thought I'd let you know that I got it sorted it's quite an easy fix!
Basically you take of the right hand cover line up the timing marks at 12 noon and the top groove on the left hand side is where the timing mark should be,set the timing mark on the rotor / alternator to the mark on the balancer cog check they line up after a couple of rotations and bobbs yer uncle. ( I do have it written down properly)
Good luck :)
Hey I know it's been a while but what Mark's
1 - 10 of 10 Posts
