P
pms07
·Guest
Anyone out there using a Baron Big Air Kit on a 1600 Classic? I'm looking for any recommendation or advice you might have.
pms
pms
someone else will correct me if i am wrong, but this is what i assume to be true. you can change the filter without putting in a programmer, but if you change the filter housing, essentially changing the intake, then you will need to reprogram the injection. you will definitely notice a difference if you did change it over.pms07 said:My Classic is stock so far. If I were to go with a BAK or Thunder what can I expect? Will I need a Power Commander or something with just that type of change?
pms
