1998 Kawi Bayou 220
OK- so after ordering a new starter, choke lever/cable, relay, regulator, etc.. I finally have a working electrical system. I am hopefully done with that for a bit.
There are a lot of details here so I hope someone is willing to read all of this!
To start the story off- Right now I have battery turning the starter, good spark, compression.
I cannot get the motor to start. Had bad gas when I got it so I rebuilt the carb with a moose kit, followed the instructions in the clymer manual and reinstalled the carb. Obviously cleaned the old gas out of the tank, got new fuel.
Before installing starter and fixing everything up- I was able to get it to pop and rev some with starter fluid (don't like using it but I had to see if there was any major problems). Then after the carb rebuild I got it started one day with the pull start, it lugged and bogged but actually ran for about a minute, got up to 3rd gear in the yard and finally quit running.
Yesterday, I couldn't get it to pop and rev with the starter fluid either by spraying it into the cylinder or the front of the carb. It would pop here and there with the starter running. I definately feel like there was some kind of 'fire' in the hole but not enough or too weak to start the motor and keep it running. I also tried to drop gas in the cyl. through the spark hole and still nothing more than a small sputter.
I am a bit of a rookie when it comes to carbs. When the carb was in pieces I adjusted the float just a little bit (less than a milimeter) because i thought it was out of wack but it may not have been. I have the bottom screw(air mix?) on the carb out 1.5 turns and the side screw (idle adjust?) out 3 turns. I also noticed on the main jet there was an o-ring that didn't seem to be in the correct spot, it was showing when the main jet was screwed in. Yesterday I couldn't ever see where there was fuel actually on the plug, but it's really hard for me to tell.
I now understand there is a special way of adjusting the float? Could this be my problem? Is it just my carb tuning that is bad? Could there be a problem with timing? I haven't ever had more than the starter off of the thing (as far as the jug/case/valve cover). Any advice/comments would be greatly appreciated! I'm tired of building this thing it's time to ride it.
THANK YOU!
THANK YOU!
