1 - 2 of 2 Posts
Discussion Starter #1 (Edited)
Hello everyone, new to the forum but I have an issue with my 88’ bayou 220. When I push the start button I get nothing. Bought a new solenoid and can start the four wheeler by using a screwdriver to jump the solenoid by touching the two bolts. Lights and kill switch work on the handlebar so I’m thinking the start button is not the issue? I tested the red plug by the solenoid (the fuses work) and the black and white wires get juice when I test them so I don’t know where to go from there. Neutral and reverse lights work too.
Get your wiring diagram out, study it and see how the system works. Once you figure that out, you can start testing. There is a starter circuit relay, a starter relay, wiring, switch, neutral switch and a bunch of other stuff.
1 - 2 of 2 Posts
