1 - 2 of 2 Posts
First and foremost i have no spark
I have replaced the coil and voltage reg.
New Spark Plug Still Nothing
I can put a hot battery in and hook it up and my neutral light and stuff comes on and when i pull the rope the lights get brighter
Im new at this stuff so im a dummy when it comes to the electrical stuff
SOMEONE PLEASE HELP
I have a 300 Bayou if this helps any. I had the same issue at first. I replaced the CDI box. Still no spark. Then the ignition coil, both located behind my battery box. Just as I thought **** it might be the magneto, i'd give away the bike at that point. I hooked up my car with jumper cables to her and the neutral light came on! She cranked over and with time a new battery and new carb and she was good to go. You have a voltage meter? Start probing around and seeing where the voltage it getting cut out.
1 - 2 of 2 Posts
