1 - 2 of 2 Posts
I have an early 90s bayou that i tried to hot wire the cdi strarted to flex out 1/8 th of an inch and made a crackin noise so i know ineed one of those was wondering if i messed any thind else. i have the 7 wire cdi wire setup and the b/r wire gets 1.3 volts ac from the stator/ magneto assembly when cranking and ohms out at 130, is that enough to power the cdi box and what else should i . I cant find specs for pick up and other things i want to check so in know what i need.
thomas
Discussion Starter · #2 ·
additional info
stator wires are141 ohms black/ red and red
pickup wires are 117 ohms black and blue
phase wires (going to rectifier) .7 ohms 2 yellow wires
no short to ground
are these readings correct can not find my manual
1 - 2 of 2 Posts
