I've got a 1995 Bayou 300 4x4 and the reverse lockout does not work. The cable from the reverse switch to the lever is connected properly, and the lever returns fully to what should be the lockout position. Nonetheless, the quad can be shifted directly from 1st to Reverse.
Has anyone here encountered this before? Any ideas what the problem might be?
It appears that I'd have to remove the driveshaft, rear differential, and sub-transmission just to get at the actual reverse lockout mechanism. I'm considering just using it the way it is. There is, of course, the possibility of damaging something by shifting into reverse while moving forward, so ideally, this should be fixed.
Any thoughts, suggestions, or advice will be greatly appreciated.
Thanks.
Thanks.
