1 - 2 of 2 Posts
96 Bayou 220, owned for couple years, problem just started, slightly difficult to shift into reverse, takes several taps, then shifting into neutral no problem, but shifting into first has to be done by reaching down and giving shift lever a good YANK by hand, then all shifting works fine until back in neutral, requires another yank by hand to go into first. I did adjust the clutch, made no difference.
Thanx for any help
Try increasing the idle speed a tiny bit. Make sure the shift lever pinch bolt is tight, i.e., make sure the shift lever isn't flopping around on the splined shift shaft.
1 - 2 of 2 Posts
