1 - 5 of 5 Posts
I just purchased a 2008 750 brute. Its been in the showroom for about a year. has never been touched. anyway, theres only one problem. Every time I use my front brakes my brute pulls to the left, a lot! I noticed the left tire is braking more than the right... wondering if its the bleeding of the brakes or the master way on top.... Could someone help me with this? by the way, im new here!!
The first thing you want to do is check your tire air pressure. These tires are very sensitive to air pressure and one that is even at only 2 psi more than the other will be larger in diameter and have greater braking force, pulling to that side.
If that is not the case, then check the circumference of all your tires with a tape measure. If one is larger from a manufacturing defect or from being overfilled and setting for a long time, that is the way it will pull.
If the brake is spongy then bleeding is in order, but normally air in a brake line will diminish braking equally and not result in pulling to one side or the other. Several motorcycle accessory manufacturers do sell a modified bleed valve that makes this process much simpler than with the OEM valve.
Sometimes the caliper slides get sticky from corrosion, and that can cause one side to pull slightly, but usually you will hear this as a squeaking or scraping from one side or the other.
Normally a caliper will not seize unless it has been submerged and water has leaked past the external seals. Then they develop a bit of corrosion and bind.
That is really easy to check, just jack the rig up and spin the wheels one by one and have a helper actuate the brakes. The wheel that continues to turn should have the caliper inspected.
Discussion Starter #5
In that case it's not the caliper...I checked the tire pressure and both front tires are at 4-1/2 psi...so thats ok... could it also be the allignment? maybe when the dealer put it together, they did a poor job? And for the tires,I didn't measure yet... by the way u have been very helpful, thankyou!!! Another little thing since u have experience in this, before purchasing my 2008 I had a 2006 brute750 carb and I find it was much fatser than the 2008... the only difference is my tires on the old one were original tire and rim...Now on my knew one I still have my original size but they are the SS mags and ITP mudlite tires..Could this affect my power on a straight away?
1 - 5 of 5 Posts
