1 - 2 of 2 Posts
Hey all,
So I found this web site while I was in search of a repair for my failed brake light. Seeing as how I found the problem and it wasn't listed here I figured I'd share. If your machine has a modulator check it. The modulator on mine went bad. Not like trying to kill me bad, just not working bad.
To determine this was the problem I ran a wire straight from the battery to the hot brake light wire. Probably not a good idea, however, this way you can make sure the light itself works.
After I determined the light worked I ran a wire to bypass the modulator. This allowed me to test the hand and foot brake connections and isolate the modulator. Once you know it's the modulator, it's a simple fix to bypass it.
And yes, every time I write modulator I hear it in Marvin the Martian's voice.
Tex
texpeterson said:
Hey all,
Tex
LMAO! :lol: The Illudium Pew-36 Explosive Space Modulator! That creature has stolen the space modulator!
1 - 2 of 2 Posts
