never done one but probobly have to split the cases. or if you pull the shift shaft bushing out(there is oil behind it) there might be a circlip you can remove and it will pull out. like i said im not sure. your local parts store should have a micro fische on it with a part break down . or they can tell you.
sorry i couldnt help more
