Dear all, more or less all my motobike's carbs quite often leak so that to stop leaking I have to hit the bowl with the bottom of a screwdriver.
I've learnt from climer that probably there is some dirty inside the bowls, so that I would like to clean them without disassemble the carbs (just because I'm not able to ).
I have some ideas but I don't want to cause some disaster so please give a hint.
1)Spray some carb cleaner inside the hole of the drain plug.
2)Fill the tank with some injector cleaner ( may be STP..,) at 50% cleaner 50% gasoline then let the mix to fill the bowl and leave it fore some days. Finally drain out the mixture.
3)To spray the carb cleaner in the throat of the carb .
Plaese give me some suggestions :redface: .
Many thanks Fab
Many thanks Fab
