grdutchie said:
1. First time ever on a forum....be gentle.
2. I just bought an 88 ninja 600r froma buddy who left it in his dads hanger for 4 years. carb is leaking fuel.
3. I have cleaned all the lines and cleaned the entire carb except the choke assembly. fuel still leaks from what appears to be carb 3 for sure and maybe 4.
4. Bike will run will full choke but at about 4000 rpm and dies when the choke is moved.
5. Should I rebuild the carbs? also fuel continues to leak long long after i turn the fuel to the off position.
1. welcome to the board. good board so far from what ive seen. :wink:
2. decent bike. will bring ya joy if we can fix it for ya.
3. you should prob. REPLACE the fuel lines to be exact. also did you inspect the NEEDLE/SEAT in the carbs ? did you check float height ? do you have a manual ? you need to figure out EXACTLY where its leaking fuel from, carb bowls, over flow lines ??? how does the tank look inside ? rusty or clean ? im betting rusty so you need to pull the tank and clean it out with an acid solution (yamaha sells one, KREEM is another brand, bike shops will carry these for you) you should also prob. pull the petcock and clean the small filter attached to the top of it. the small screens may be clogged. thats also prob. a vacumn petcock and may not get enough vacumn to pull it open. the diaphram may be old/stiff/hard and not open enough to let enough fuel thru. might have a small hole in the rubber line going to the petcock. now do you see why you need a manual ? :wink:
4. sounds like the PILOT JETS are still clogged. get the bike started,kick the choke off and just keep blipping the throttle to keep it running and see if all pipes get hot (spray with water) , if all the pipes dont get hot then the pilot jets are still clogged. i would just pull the carbs again and make sure you cleaned all the jets well enough. i can send you a pic of the jets im talking about if you need.
[email protected]
you will need to pull them out and push a small piece of wire thru them.
5. after sitting that long i would check the diaphrams in the top of the carbs and make sure they are still rubbery/flexible and not ripped/hard.
i would pull all the jets out and make sure they are clean. the fuel coming out points at a couple possibilities to me. one-the petcock is screwed up and not stopping flow OR two-the needle/seats are junk and wont stop the flow IN the carb, three-the floats are history and not floating correctly and stopping the fuel.
good luck
