1 - 7 of 7 Posts
I Have a 04 500r And I need to know if anyone can post a picture of were the idle mixture screw is And how do you go about adjusting them I have heard you have to pull the carbs and drill out the plug first. And How do you go about pulling the carbs out do you have to pull the gas tank and all of that Stuff to get to them. Thanks
· AZ's Official Mechanic
send me an email and ill send ya a pic of the AIR/FUEL SCREWS. [email protected]
as for pulling the carbs, get a manual before attempting this.
WHY ARE YOU WANTING TO PLAY WITH THE MIXTURE SCREWS ??
500r said:
I did the air box mod you now drilled the hole And know I need to adjust the carbs.
point me too this mod, i would like to see what else is involved. if you add air your gonna have to add air across the RPM range. do they have you playing with the main jets/needles also ? :?:
Drain your carbs 1st.
To get the carbs pulled, remove the airbox and tank and you should be able to get at the carbs fairly easy. Loosen up the hose clamps and work the rubber hose off the carbs leaving the rubber hoses attached to the'll have to disconnect the choke and throttle cable along with all the vacuum and fuels hoses attached.
1 - 7 of 7 Posts
