1 - 9 of 9 Posts
Sorry for the goofy post title (try singing it)!! Looking for a good o-ring style chain. Size is 630 (96 links). Thanks.
Discussion Starter #4
This will require sprocket changes as well?
Gasket Killer
Isn't that a gearing change? I initially saw that as @ Z1 while perusing their porn.....er... parts sections but thought that it would kill the highway-bility (still a fan of the G. Bush school of Engrish). In town, that would be great! Probably pull the wheel off when that frickin' Gixxer stops by my house and revs while I'm working on the ride. But on a trip to another state, would it be killing mileage, increase the noise, shove the vibrations into another level, etc.?
You guys are killing me!
You can do what ever you like on the gearing with the 530 conversion including keeping the same ratio or going up or down. I went to a higher gear ratio when I did the 530 conversion and bumped my mpg up by about 8-9mpg on the highway. It takes longer to wind out each gear now and it's not as quick off the line any more but it's great for just cruising and it's still got plenty of getup and go.
Gasket Killer
Excellent Stargate! I'll have to check it out then. I'll get a feel for what's she's capable of for a little bit, then decide which way to go with the gearing. I thought the 530 was strictly a gear change, didn't realize it was what it was.
And this is why you guys continue to rock.
Obfuscation Engineer
just do it . Jeff will be more than happy to help you finger out the gearing . do not repeat do not get the lo-budget ebay item unless you like killing chains and other expensive bits . I found the lower priced conversions have adequate sprockets (sunstar in one case ) but complete trash for a chain . just call Jeff @ z-1 and be done w/ it .
~kop
1 - 9 of 9 Posts
