1 - 12 of 12 Posts
What are the pros and cons?
I have an '82 KZ750N and wondering if its possible to change over to chain drive for more aftermarket wheel options.
Am I being silly? Thanks
Obsessed by Z1's
Changing over is not something that's easy - lots of changes - much easier to sell and buy a chain drive bike.
Shaft drive requires less maintenance and can be smoother riding
Shaft bikes produce less HP at the rear wheel
With chain bikes you can change the final drive ratios easily just by changing sprockets.
Chain bikes are less complicated.
i have a z1000st (uk equivalent of your kz1000 shaft) and it has the adantage of being maintenance free (just requires oil changes in the diff) and obviously cheaper than the cost of sprockets and chain. However, as you say there is limited option for customising and at low speeds is actually quite jumpy, it doesn't like anything under 30mph. very torquey though and by all accounts one of the better shaft drive classic bikes, along with the gs850. conversions can be done at high cost. better off with chain drive if you want to customise it.
1 - 12 of 12 Posts
