I have put an aftermarker digital instrumentation panel on my custom 78 KZ650. From the right side of the motor which i believe is the ignition side there are three wires red,white and black. My question is this:Where is the red power wire supposed to be connected into the system? Currently it is connected to a switched and fused lead coming off of my ignition switch....the motorcycle runs fine this way but the new unit i put on is overloaded because the power supply is not constant and all the instrumentation flickers and is unusable. I believe it also has over heated some of the circuits.I don't believe there was any permanent damage ,but i took the fuses out just in case. If anyone has a diagram etc. I would appreciate your input. The bike was originally a KZ650-D1 SR which I found out from the engine serial number KZ650DE001447. Thanks Joe
