Spookyb4-The owner's manual says to situate the motorcycle so that it is perpendicular to the ground (on its side stand).The coolant level should be between the upper and lower level lines through the transparent hose at the coolant reserve tank.Check the level when the engine is cold(room Temperature).Hope this helps.Vanb.
