Need some advice, On a weekend ride I had stopped and looked things over, the front speedo connector was almost off, with small amount grease leaking out, I tightened it up, Today I checked the torque on the front axle, It was WAY too loose, so I set it at 80 ft lbs with the pinch bolt loosened, After this took it out for a 2 mile ride, stopped to look it over, noticed the Speedo gear box and the lower right fork was hot,
not too hot to touch but Hot. the left fork was nice and cool.
Could this be a problem? what else do I need to check for?
I have not noticed any unusual sounds\squeaks coming from up front
1200 miles on the bike,
Thank you group for any input.
Dave
Dave
