1 - 5 of 5 Posts
if your just cleaning the ports of carbon or oil build up yes carb clean and a old tooth brush will do the trick.
but if your goin to clean the casting marks or dimples and make a smooth port then a dremel and different types of tools will do the trick for that ,but if you have never done one before may want a pro to do it you can damage the port and cause more turbulance and make no no power gain but loss
1 - 5 of 5 Posts
