What are you talking about? Are you talking about those little metal clips that have what looks like a nut on one side and a flat side on the other and are usually attached to some part of the moldings of the bike? If you are... I hate those things, they come right off once the screws are out and then your mind goes crazy hoping not to lose one. :evil:
I tried looking around cause I didn't know what you were talking about. Now I get it! I'm such a newb! I found grips but not for our style of bike. Oh well I tried. Maybe someone else can do better.
Is anyone here really knowledgeable on the ignition system of a C1? Bought a project bike with no spark. I have gone through everything and expect a bad CDI. Looking for second opinions.
All wires good no shorts or breaks
Pickup coil Ohm tested good
Cam sensor ohm tested good
All safety...
Here's a tough little question. I'm in the process of removing an engine from a 1985 GPZ900R.
I've removed everything that needs to be removed as per the factory service manual but the engine won't come out.
The engine is held in the frame with two long bolts at the rear and two shorter ones...
Hello everyone,
Since inline 4 cylinder, low displacement engines are not put in motorcycles anymore I would like to purchase a zxr 400. The only problem I have with the motorcycle is the carburetors.
I've owned 2 carbureted motorcycles and always had trouble with the carbs.
So the plan is to...
Hi there,
I dropped my bike off today at the dealer to do the first initial 1,000km service.
The bike is a 2018/2019 Ninja 650L and I was told it would be done in 2-3 hours(9am Drop off-12pm Pickup). When I came back they said another 10 minutes or so until 20 minutes later the dealership owner...
