I've seen that one before and would look great on my bike. The problem is I cant find a brake lever to match. It seems they just sell the clutch lever and perch only, unless I missed something.
Yeah, that one is clutch perch and lever only.
When you say 'match', do you mean that the brake lever needs to have the speed-adjuster too?... are your brakes cable operated or hydraulic? If the latter, it won't have an adjuster like that ever. If cable operated, I still don't think I've ever seen a speed-adjust for cable-brakes. It just wasn't ever a thing back in the day of drum/cable-operated brakes.
So if its just aesthetics b/c you don't want a dogleg/modern lever on the left paired with the OEM 'banana' lever on the right, you're not going to find a modern type clutch-perch setup that has a speed-adjuster like these with an old-school type lever (non dog-leg) as was found on older bikes. I mean, maybe there's one out there, but I've never seen it.
Best you could try if you want that is to buy this ProTaper one, take the lever off, measure the pivot hole dia and the thickness of that pivot area and try to find a old-school looking lever that has the same measurements. The cut/angle on the lever has to match the perch too... they don't all have that same sort of cut-out area, especially mixing modern stuff with old-school stuff. Take a good look at the perch where the lever rests against it.. there's some angles there that need to match.
This kind of hybrid setup is gonna be iffy... you will prob wind up buying a few levers before you find one that fits. That's why I was saying what I said in my original reply that you're safer buying the perch + lever together if you just wanted something that worked w/out fuss.
You could maybe look for replacement brake levers that match the style of the ProTaper one (a dogleg), but unless it's made by ProTaper, it probably won't match exactly and may not fit the brake perch.
Or, if you're ok with having 2 dogleg/modern-looking levers, maybe buy a 2nd ProTaper clutch perch/lever and just flip it over for use on the brake side. The rubber cover would pretty much cover up any odd-looking stuff that normally faces 'down' I imagine. This is, again, assuming you have drum/cable operated front brake. If hydraulic, nevermind this isn't the solution.
I can't say I've ever tried something like that, nor do I know anyone that has. Surely someone has used a clutch setup as a brake setup for cable-operated brakes at some point? Or, maybe the brake cable-end is different sized and won't fit into the typical clutch lever end-recess?
You'd be a trailblazer for trying it. If you do, post your progress!
Having said all that...
There are a lot of old-school style clutch perch+levers out there that have a standard looking knurled adjustment-wheel setup though that will match your OEM brake lever, or near enough that only a real close inspection would find issues.
