What’s up!! I have a problem that I need help with!! I have a 1998 kx125 and I just installed a new clutch and basket on it. The problem I have is that the when I pull in the clutch the clutch lever will not return to it normal position. The actuator arm on the casing will not spring back. By looking at the manual It looks like the clutch springs are what returns the actuator arm??? Which then brings the clutch lever back to it normal position. I have the clutch calbe adjusted all the way out and it is still very very sloppy. Its almost like their should be a spring on the actuator arm inside the casing that pushes it back. Any ideas?
