1 - 2 of 2 Posts
Did you figure it out? Only things I can think of is possibly you didn't soak the friction plates in oil overnight before installing? Depending on whether or not you mean it won't release or won't engage.
Or the spring was worn. Most Vulcan 1500 clutch problems were a bad spring and not the disks. People used the 1500 meanstreak spring instead. And a "Judge's washer" for better reliability
poke around in here: Maintenance Tips for Vulcans and Other Motorcycles - Gadget's Fixit Page or here: Vulcan Gadgets Fixit Page For Kawasaki Nomad & Classic Modification Maintenance & Repair some of the links are dead now but between the two there's still a lot of good info.
This one in particular: Vulcan 1500/1600 Clutch Replacement
1 - 2 of 2 Posts
