1: does the 97 vulcan 1500 VNA series have an automatic pre ignition compression release
If so can it be modified to a manual release? The reason that I ask: It sounds as if the timing is retarded and more so since I dumped it
2: The other day was riding by the river when I dumped it in a sand dune.
Since then it has run really crappy until taken to an painfully high RPM and
seems to be running lean at lower RPM
You should see the wear on my chicken strips since
Thanks in advance for any tips
