1 - 1 of 1 Posts
Hears what you have to do
1) Drain the coolant the coolant drain plug is at the bottom of the pump
2) Take all the hoses of the pump
3) Take out the bolts holding the pump in place you will have to wiggle it about to loosen it then pull it out what you should see at the back of the pump there it the drive for the pump there should be a O-ring and a drainage hole it could be the O-ring witch has gone you hope cos if its coming from the drainage hole in the pump the pump’s had it and you will have to get your hands on a new one or secd hand one will do. This is out the HAYNES MANUAL. Witch says that you cannot rebuild the pump. I will scan be book and send you the pics that show what I mean
:D :D :D
1 - 1 of 1 Posts
