Ok so I've decided to take a look at my plugs after a couple of times the bike stalling on me. Usually this happens the first time I start my bike on that day. If I give it gas, it'll seize and stall. I usually have to wait a min or so to start riding it or, once the rpms fall, the bike will stall. On a couple of occasions I'll be riding hard and then let off the gas; the rpms will fall, but below the idle range and the bike will stall at whatever speed I'll be at (100+). Take a look at my plugs for me. I'm having a hard time identifying the problem(if there is one) using this: Spark Plugs.
Ok for those who don't know what I ride...these came out of my FI ZX6R. So unless you know how to lower the amount of gas going into an FI bike, please please stop saying carbs...
Are these plugs fouled out? If so, too hot, too rich, too cold or too lean? If not, is there a way to clean the plugs since I have them out?
*note, bike has slip-on and high flow rate air filter. No Pc3 yet. 10,000km put on these plugs. Half a can of seafoam was used the day before I pulled them out.
Flash
No flash
Flash
No flash
