1 - 2 of 2 Posts
anyone out there installed green (3 ohm) dyna's on their 80 KZ1000 B4? Just picked them up today...so do i simply cut the pink & black/dark green primary wires from the existing coils and install on the new dyna greens? i think redline cicles mentioned the balast resistor (pink connection) needs to be taken out of the circuit...does that mean i simpy do not connect the pink primary wires to the coils?
thanks in advace for your help.
ace
Obsessed by Z1's
If you plan on running the 3.0 ohm green Dyna coils, then you will need to remove the ballast resistors from the wiring. It's fairly simple to do. We have before/after wiring diagrams we provide with the coils if the customer has a 79 or 80 KZ1000.
1 - 2 of 2 Posts
