Has anyone else who installed the ds2-1 on thier 79 KZ1000 ltd b-3 had an issue with the rotor not fitting over the shaft? .... man that reads bad.
Shaft? Are you trying to bolt the rotor directly to the end of the crank?Has anyone else who installed the ds2-1 on thier 79 KZ1000 ltd b-3 had an issue with the rotor not fitting over the shaft? .... man that reads bad.
lmao, yeah Jeff i was trying to put it on the crank shaft...lmao No bro not trying to put it on the crank shaft. I did however realize my mistake.Shaft? Are you trying to bolt the rotor directly to the end of the crank?
The bolt supplied with the ignition goes thru the rotor. The rotor sits inside the mechanical advancer arms - the advancer and rotor get bolted to the end of the crank.
I thought 80 was the first year for any kaw to have electronic ignition.I've got a '79 B3 and I just picked up a used factory electronic ignition for it on Ebay
