1 - 9 of 9 Posts
Hi, I’m a Kwak fan, and have had numerous bikes, all second hand and mostly old. I currently have a Ninja 300, an EN 500, and a GPZ 1000 rx, which has been undergoing major surgery at a local bike mechanic’s for nearly four years now, and the guy won’t give me any more information about how it’s going! But meantime my 1991 EN 500 had a starting problem. I replaced the battery, which was due for renewal anyway, and also replaced the starter solenoid. Initially it started first time, but ever since then, when I try to start it, it just makes a single clicking sound, and no more. Any advice would be most gratefully received! Many thanks, Lenin
Many thanks. By the way, one thing I didn’t mention is that I am a completely useless mechanic! It’s difficult mentioning this in biking circles, where everyone seems able to strip their bikes down with ease, but I am useless, and when I joined a local motorbike club many years ago the head guy looked at something I had done to my 250 AJS, and said that I should never go near another bike with a spanner in my hand!
OK so useless on the Spanners admission out of the way we can move on ;)
Do you have a Digital Multi Meter ?
They aint expensive and are a great Diagnostic tool especially as we can guide you through the process (y)
Super Moderator
Lenin, not many would admit or be so candid about their lack of mechanical skills. My respect for you has gone up.
A load test can be done for free by almost any place that sells vehicle batteries. I know the battery is new, but the symptoms you describe indicate a possible bad or discharged battery. Voltage alone is not a good indicator of battery health, hence the need for a load test. If you cannot take it for a load test, I think Greenisbest has some ideas on how you can use a multi-meter to do some testing. I agree with him that its a great tool to have, not only for working on cars and bikes but around the home also.
By the way, I assume you have checked to make sure your battery terminals are clean and tight?
Thank you so much for your information and understanding. Never too late to learn, perhaps? I bought the battery from just down the road, so can take it back easily enough. And, yes I did ensure that the terminals were clean and tight!
I‘ll buy a Multi Meter, and learn to use it, and thanks for the advice.........
1 - 9 of 9 Posts
