It's a 1992 KLE 500 with 33.5K on the clock; no matter how open the throttle is, when letting out the clutch lever the engine stalls as soon as it reaches the biting point. Although the engine seems to be running fine while in neutral/clutch disengaged, it's like there's no power output at all.
Any ideas?
The bike was running fine when I first got it a couple weeks ago; then I gave everything a good clean, changed the air filter and dropped the bike :redface: (this problem occurred before the drop, but at that point the front calliper pistons had stuck - I dropped the bike while trying to force the wheel to turn... the wheel now turns freely so it's not the brakes that are causing the problem anymore). Now it won't go anywhere
I've not touched the engine or carbs since getting it.
Any ideas?
