1 - 5 of 5 Posts
Super Moderator
I run my front tire at 22 PSI and 28 on the rear, on my KLR 650. It is best to go with the Kawi spec for your bike, unless you really know what you are doing.
What makes you think that 32 is too low?
Super Moderator
Ok, as greenisbest points out, 32 is factory spec so you are good to go unless the tire seems soft, in which case I would suspect your tire pressure gage is faulty.
1 - 5 of 5 Posts
