CABLES
Set your throttle to have about 2-3mm (0.08-0.12") of play in it, same with the choke cable. Your Idle RPM is up to you, but try it at about 1,300 RPM and see how you like it. Some people will adjust it down to 1,000RPM for inspections because they test by contaminants in Ubic ft per minute or something like that ...some people like 1,500RPM an dyou will find track racing guys setting the RPM's at 3,000RPM, which would be way more thanyou would need for the street. the throttle(idle adjustment screw) has a little knob adjustment on the right side of the bike. twist it just a little like a quarter turn and then twist the throtle and let go of it to see if the rpm's are now just right or to high. If you don't have new plugs get some and make sure that they are the sme ones that you have, don't go switching brands or heat ranges till AFTER you break the bike in. Then take the old plugs and soak them in white vinegar overnight to clean them and blow them dry...they should still be good...DO NOT OVER TIGHTEN your Plugs when you put them back in...just snug them into place...steel plugs in an aluminum head and you can strip tehm very easy...when you start them put just a little antiseize compound on the threads or a little oil on them and ALWAYS start them by hand, NEVER with a wrench. your choke cable should not need adjusting unless ther is NO play in the choke lever on the handle bars...if ther is any play it is enough. IF ther isn't any play then follow the cable down, and loosen the cable and allow them to get closer together before you tighten the locking nut...this will allow more play on the lever on the handlebars. The most important thing that anybody can do when they have a bike is to log EVERYTHING into one log book. Keep very accurate logs. put it on the computer, but also print it out an dhave it in a notebook so that shold it ever occur you can take the notebook in to a service manager/mechanic and show him documentation backing up your statement and perhaps he can seee something/a trend and go straiht to the problem to fix it...this cannot be overstressed or over addressed. Even lubbing your chain, and not only with what but log in when you bought the chain lube what brand but even the price and date. When it comes to the 5000 mile checkup take your owners manual and make sure that EVERYTHING that is in it is covered and checked off by the mechanic. IF you don't have an owners manual (should have been under theseat or with your paperwork when you bought it then order one from BEARTOOTH KAWASAKI our forum sponsor and you will get the 10% discount and you can find out all of the stuff that you just asked. I would also order the Maintenance Manual...it is cheap and it shows you in larger pictures and even what to turn and how to do things in a very detailed manner...
call Beartooth at 1-800-556-3098, and order the Owners Manual and the Maintenance Manual
P.S. Thanks, Peter, for the compliment...I'm not really an expert, and i'm only an ANGELL by name! ZX-2R
