I've got an older EX500 ('89, A3) that suddenly developed a tach that reads (likely) twice the actual RPMs that the motor is running. I've:
a) Checked the wiring harness - no shorts / opens, verified that CDI box to coil circuit wiring is not shorted together or to ground
b) Checked the pickup coils - in spec, no shorts / opens
c) Checked the ignition coils - in spec, no shorts / opens
d) Swapped a (used) CDI box in, no change
e) Replaced Plugs - no change
f) Swapped Coils & caps - no change
g) Replaced Coils & Caps - no change
I put a frequency counter on the output circuit for #1 cylinder, and it would suggest that the tach is "reading" correctly (i.e. 45-50 Hz for 2500-3000 RPM tach reading where I would "expect" 22.5-25Hz for 1250-1500 RPM tach readings). Can anyone verify that the tach on an A-Series EX500 gets "one" pulse per rev, or does it get two?
Any thoughts? (And no, I don't have another tach to swap out yet...)
Thanks!
Thanks!
