1 - 8 of 8 Posts
i put on my new short stalk signals about an hour ago and all but 1 work fine. the left front stays on constant and wont flash so the rear left blinks rapidly. i have double checked all my wiring and cant find a solution. any ideas?
Did you get the dual filament for the front? Three wire? If you only have the single filament, two wire, you have the running light hooked up, but not the blinker. When one blinker blinks real fast, it normally means the bulb on the other is out.
wow, something so small and stupid as the running light and turn signal leads being wired backwards from the factory can cause hours of confusion and anger.
thx for suggesting that diver, that was the problem.
man just changing the lights changes the whole appearence of the bike.
time for a short ride before work :grin: :grin:
Glad it worked! Post a pic, I've wanted to change my lights out, but have not found anything I like yet. Also, are they as bright as the stock ones?
Later
1 - 8 of 8 Posts
