Hello. I recently purchased an 88 EX500 off a racer (I'm planning on racing it). It's in good shape, but the bike won't run without the choke on. Even then, I have to rev it a little to keep it going. Above about 5000 (estimated, someone at my last apartment building stole my tachometer) it begins to bog out, drops down to about 2000 revs, and then dies if I twist the throttle further. It dies completely if the choke is off. I went to clean the carbs, but upon disassembling them they were already extremely clean. The bike had been drained of all fluids when I bought it. The gas flow from the tank appears to be adequate when I apply suction to the vacuum line on the petcock, but I'm of course not sure if it is. I looked at my Clymer's guide, and it says the idle screws are permanently set on US models. I think I may have to place a vacuum cap on the emissions port between the two carburetors, but beyond that, I'm not sure what it could be. Everything seems to point to the carburetors, but beside the emissions port, what else could it be? Any help would be much appreciated. I did see a post addressing this issue from a few months back, but it appears to have a different root cause, and my model is much older..
A few more things: The bike has an aftermarket Muzzy exhaust, and appears to have a jet kit. The needles don't look stock, they have the same sharp point look of the Dynojet kit, not the blunt look of the stock needles. Maybe I need to adjust the height of the needles, but wouldn't that really only come into play at high RPMs?
