So the F11 is back together. I have installed and adjusted the clutch release per the manual, however when the bike is NOT running, but in gear, it won't release when the clutch lever is pulled in. I have double checked everything per the manual and can't figure it out.
The only think I can think of is that this is normal when the bike is not running.
Can anyone comment? Again - if it's in gear, shut off, I figured I could pull the clutch lever in and roll the bike freely - not the case.
What's wrong?
FYI: I didn't remove/replace any of the clutch plates, etc. I only had the release mechanism on the left removed and was replaced and adjusted per the book - I'm stumped.
Help!
J
What's wrong?
Help!
J
