1 - 1 of 1 Posts
I am having some issues with the crankshaft weights hitting the sides of the case when I tighten the case screws down on my 1975 F11 250.
The new bearings went in perfectly after freezing them. The crank was rebuilt professionally with new rod, washers, bearing.
I used a Tusk puller to pull the crank into the left case half. I installed the transmission, applied a thin coat of Yamabond and tapped things together.
At first I got interference on the right side - the crank wouldn't spin - the oil receiver was hitting the bearing retainer in the case. So I pulled the crank into the left case a bit more, and then got interference on that side.
I pulled everything apart again :(
What am I doing wrong?
All the bearings, seals, and transmission went in perfectly. I thought the cas halves would be the least of my worries!
Can anyone shed some light?
1 - 1 of 1 Posts
