all you guys with SUZUKI FI may take hede here. (it may encompass other models/brands aso but it only has to do with the FI bikes)
on some of the THROTTLE BODIES the factory has put a special ring of material inside the bodies where the butterfly meets the body itself. it will be black in color. DO NOT SPRAY THIS WITH CARB CLEANER OR ANY OTHER SOLVENT !! if you remove this stripe of material your bike will NOT run correctly so ive been told . just be careful and use a clean rag.
