1 - 7 of 7 Posts
Attached is a picture of a standard tubing clamp used with pipe. conduit, tubing, etc. I have been trying to find heavy duty versions at around 1 inch and thought they would be easy to find. Apparently not so. I've looked at OSH, True Value, and others without luck. Anyone seen these anywhere? Thanks!
They are called Adel clamps. Any industrial fastener place should have them. I run into the same thing here. OSH, Home Depot and Lowe's are no go, but I have two fastener supplier here that carry them.
you could allways make your own,
take the tube and wrap the metal around it and then just drill a hole. you can find flat stock 1" wide at any hardware store.i like to make things it gives me a sence of pride that i made it-corey-
1 - 7 of 7 Posts
