DRAGGING
IF you still have a centerstand put it down and set back in the seat to get the front end off of the ground and see if when you push or pull the bars back and forth forward and backwards at the same time if your loose at the frame whre the bearings are for steering...you know whre the tree is...turn the bars full left and right...to see if ther eis nay drag...then find someone heavy to set on the bike seat and hold the bars straight. try twisting the wheel back and forth (while the guy on the bike resists your twisting) to check the forks and the bearings..bearings in booth the tree and in the front wheel...then with hour hands on foth forks push pullback and forth to see if you can feel any play....another thing to do is to make sure that the front wheel spins freely nad you feel no bearing grinding and that the wheel turns smoothly and without side to side play. Then have the person on hte seat sit up against the tank so that the rear of the bike is off the ground and se that your swingarm is not loose, wheel is not wobling...sort of the same thing as the front...What ever you find...let us know!
