OK so this has been a bit of a project getting this bike to run. I purchased it a few weeks ago and would like to get a ride in before there's snow on the ground, but since it just started snowing as I type my chances are growing rather slim.
The bike had been sitting for 2+ years when I bought it, so first up was and oil change, and plugs/wires. a little fresh gas and some starter fluid and it was running, wow that was easy I thought. now by running, i mean it ran, but not smoothly, and it wouldn't idle. I could hold the throttle and keep the engine running, again roughly, at 1000rpm, but If i let the throttle go instant stall.
So i figured the idle passages (needle) was all gummed up, and proceeded to take the carbs off, make a little love to them with cleaning fluid, and then reinstall. fist off old fuel smells absolutely horrible, and second some of my passages were so plugged i couldn't see light through the jets. 1 can of carb cleaner, 6 thousand q-tips and a hurricane of compressed air and I was all set.
all back together I plug in the fuel line and let her rip. I got a no start, and then fuel was shooting out of the carbs (no air filters) and spilling all over the place. So I drained the bike's fuel and came right here, I'm guessing my next step is to look at float levels and the like but have never done that before, infact I've never worked on anything that wasn't diesel and fuel injected.
So my questions are:
1) Do you think i am correct in relating this fuel everywhere problem to an improper (high) float level?
2) Are there any other conditions that can cause this?
3) Is there any special trick on how to adjust the float level or do the carbs have to come off again?
4) Is there any chance that my engine is now filled with fuel and warrants me pulling plugs to vac out the fuel and doing another oil change?
I appreciate all of your help and eagerly await your response.
