1 - 7 of 7 Posts
Anyone have this issue, with the engine popping and almost acting like she's starving for fuel. But if I accelerate hard, it evens out until I let off the throttle. Current set-up is:
'98 Vulcan VN800 Classic
Modified air cleaner cover with K&N filter
Dynojet stage 1 carb kit and Vance & Hines exhaust. New plugs as well as fresh oil.
I have read through forums about similar issues.
Any advice?
I'll pull them tonight and check. I have the main needle on the second notch, as per Dynojet's install instructions, as well as the mixture screw at 3 1/2 turns. I'll keep you posted, thanks🍻
Yeah, it's lean, it should have a nice tannish color. You probably should go up one jet size, don't mes with the needle any more, that won't give you what you need. :)
1 - 7 of 7 Posts
