1 - 6 of 6 Posts
Hello! I am new to biking and also new on this site. I have a KZ650D from 1981, and I am looking for a new fuel petcock since mine is missing. Bolt distance measured is 44 mm.
Does anyone have information regarding a replacement part for this component?
In advance, thank you for your help.
I'm pretty sure you can use the petcock from a KZ1000P police bike up to 2001.
Kawasaki part number = 51023-1039. It's the same as the 1982-83 KZ650-CSR.
The 51023-1375 petcock found on the 2002-05 1000P Police models might work as well as I think the bolt-hole spacing is 44mm.
You should verify the bolt-hole spacing center-to-center of the replacement petcock. I'm pretty sure the police bike is 44mm, though. Also, Z1Enterprises dot com sells an aftermarket Suzuki vacuum petcock that's 44mm.
1 - 6 of 6 Posts
