1 - 1 of 1 Posts
Hello everyone,
I have a 1996 Kawasaki Voyager 1200, when i start the bike fuel pump comes on, after a minute or so fuel starts running out the hoses on the bottom of the carb the drain screws are closed. if I disconnect pump after starting bike runs fine. I have tested voltage at connector by fuel pump and voltage is constant after starting. One weird thing if I take the lead from the voltmeter and touch the one pin the bike dies down and begings running rough till i remove the test lead. i have disconnected every relay i could find but voltage remains the same. from what ive read is pump should shut off after several seconds. Any suggestions would be great. thanks
1 - 1 of 1 Posts
