Hi all. New to the forum. I have a 2006 1600 Nomad I bought new. I was working on an electrical issue and had the fuse box off its mounting. I was running the motor and noticed a slight plastic melting odor. I wasn't careful and the fuse box was on the exhaust pipe. Disfigured but functional. I found a nice one on EBAY. My question is how to disconnect the wire bundles from the original box. I don't want to wreck anything. If anyone is familiar with the process I would sure appreciate the information of where to press , pull, etc. Thank you in advance.
Don’t ya just hate it when you break your own toys!!! Look at the connections closely, they all will have little tabs to be pushed in order to be disconnected. Get some dielectric grease and pack the connections before reassembly. Take a picture before so everything goes back as it was.
Kawasaki VULCAN 1600 NOMAD Manual Online: junction box, Junction Box Fuse Circuit Inspection, Starter Circuit/Headlight Relay Inspection. The Junction Box [A] Has Fuses [B], Relays, And Diodes. The Relays And Diodes Can Not Be Removed. Junction Box Fuse Circuit Inspection • Remove The...
www.manualslib.com
Related Threads
2.3M posts
133.7K members
Since 2003
