What brand of gas gets you the best mpg? If I use anything but Texaco gas I go through a tank pretty fast. What's the best for you? Does anyone notice a difference?
Fill up at the coolest part of the night when gasoline is more dense or first thing early in the morning after the gas has cooled the most in the underground tanks. They only charge you by the gallon and not how dense the gasoline is!siasmaster said:I used to get 76 but when I lived 25 miles away from work, I noticed I had to fill up every 1.5 days. So I could make it to work and back, then only to work again the next time. When I got Texaco I could make it to work and back twice.
Yah, but the coolest part of the night here is still 85 degrees.1Adam12 said:Fill up at the coolest part of the night when gasoline is more dense or first thing early in the morning after the gas has cooled the most in the underground tanks. They only charge you by the gallon and not how dense the gasoline is!
I've heard that before, but I doubt that the temperatures really change much in an underground tank, especially when you consider that the pump sucks from the bottom of the tank. Maybe I'll get out a thermometer and try it some day. Then I can run some calculations to figure out how much dollar difference it makes. I'll bet it's less than a nickel for a tank -- hardly worth thinking about it if you ask me.1Adam12 said:Fill up at the coolest part of the night when gasoline is more dense or first thing early in the morning after the gas has cooled the most in the underground tanks.
ya none of the stupid MTBE bullshit :!:01zx7r said:I notice a difference because they don't put that whatever the heck it is additive in it that reduces emissions. Seems like I can go further on a tank then.
