1 - 8 of 8 Posts
I have a '93, so I don't know how much of a difference there is. To get to mine all I had to do is:
1) Remove the gas tank
2) Remove the air box
From that point, the carbs are just held on by hose clamps. I took mine all the way off, so I could get at the bottom bowls to clean them out.
Good luck
The best way I know of is to get rid of the air box, and get four individual air filters.
CARBS
some people just don't believe in the cheaper gas with the Ethanol in it. You get some really wierd comments and arguments. Alcohol will run great (white lightning), gives you more power (like Alcohol Dragsters) but requires larger jets. With the 10% that is available at the pump I'd say change the fuel filter and tun the Ethanol gas.
IF you can get to the screws at the bottom of the bowls, you can use carb cleaner through the backdoor...the Ethanol will do the rest of the work. I just wouldn't do any prolonged cross country Wide Open Throttle runs with out checking the spark plugs...it might run a little lean at WOT. :shock:
I also have an '87 750, can't tell you about the air box mines been gone for along time for the K&N's. But taking the carbs off is easy and about the only way to clean them good. they are real simple to clean just take your time and be careful with the screws that hold the bowls on, they are soft aluminum and easy to strip, use a good fitting phillips.
Here's a picture of my dinasour.
I agree 100% with ******.... I have a 600r that sat for some time and I tried everything that pep-boys said would clean the carbs out..... wasted time, money and pride. Pull em off, and Freakinout also hit it on... grab a manual....I swear next to Freak,,,it is your best friend........
1 - 8 of 8 Posts
