1 - 4 of 4 Posts
HI,:redface:
I have a problem with my gpx600R which runs fine and from startup goes into neutral but once ridden wont drop back into neutral without a big jolt on the foot lever and even then you usually need to lean over and yank it into neutral by hand, has anyone seen this before and know how to fix this,
thanks
GPX Dave
Need a little more info. Do you shift down to first gear, then try to put it in neutral while at a complete stop? It won't go in then? Or are you trying to get there from second?
The bike is in 1st and im at a complete stop yet until i cut the power neutral is not available, then you can start the bike which will be in neutral until you go for a ride and arrive without neutral available till you cut the power again its very frustrating and im struggeling to find the solution.
just check to make sure your clutch is fully releasing if it is i would say you may need to look at the (gear selecting fork?) some one else will know exactly whati ts called.
1 - 4 of 4 Posts
